New SS Brake lines
New SS Brake lines
Well my SS brake lines came in today Britpart DA241340S, the +40mm ones. I plan on putting them on tonight after work. Already got 3 large bottles of DOT4 brake fluid ( I want to go ahead and do a flush while im under there).
1.can I do the bleeding and flushing by myself i've done it before but always with another person helping.
2. any other things I might need or advice, I want to do this right since it is only my brakes.
Otherwise this seems like a pretty straightforward install
This is a bit different than the one I've seen but you could take a trip to your O'Reillys.
| O'Reilly Auto Parts
| O'Reilly Auto Parts
[hi-jack] Is that what it looks like? I was at Harbor Freight last week and I was looking for the "One Man Bleeder." I saw that thing, but I did not think that was it. I was expecting to see some sort of check valve [/hi-jack]
Otherwise, you can get the pistol-grip bleeder. I never liked those. You can make a pressure bleeder out of a garden sprayer, some hose, and a MC cap. Otherwise you can spend the money on a vacuum bleeder that will come in handy for more than one project.
The brake lines are straight forward, since you know how to bleed, the rest is simple. Since this will be the first time those things will come off, clean the area you will be working on and any misc. parts associated with the job. There will be crud, so you know the drill.
It is wise to use flare wrenches. If you do not have a set, your normal (right size), wrench will do..... Just make sure you take your time and not damage the nuts. The remaining tools, you probably already have in your box, flat head screw driver, long nose pliers, etc....
On installation, loosely tighten both ends on all corners, then tighten all at the same time. This will ensure you torque them equally. Just don't over tighten, It doesn't take much to do damage.
In regards to bleeding....
A family member or friend (tall enough), I find is the best "tool" for the job. But, there are time when no one IS around.....use a power type bleeder. The process will ensure that air is driven out.
