No AC or fan at any speed.
96 Disco 1 SE7. Just went on a 2.5 hour drive and she ran like a top. About 20mins from destination I decide to roll the windows up and turn on the ac.
Nothing.
No fan at any speed. No air recycle. No rear blower motor. Nothing.
If I press the AC button I can hear the electric fans turn on but nothing blows out.
Worked perfect and cold yesterday. Only recent electric thing I did was the Window ECU Bypass to get my rear windows to roll back up (which only worked for a day now they don’t roll down lol).
Fuses look good unless I’m overlooking one. Anyone have any ideas? Could the window bypass and this problem have any relation?
Nothing.
That’s what happened when I first bought her last year. Slider worked on 1 and 4 but nothing in between. Bought a new climate control set up and it fixed her. The weird things is, I have a blower motor in the rear for the rear ac but it doesn’t work either. And the controls in the rear won’t turn it on as well.
Okay cool, I'll look into it! On a Facebook group, someone is having the same issue. Both of us had recently done the Window ECU Bypass before this occurrence. Should I undo the bypass and splice everything back the way they were? I don't have any rear window action anyway despite the bypass so I'm not losing anything. Thanks for the help btw!
no light, but the fans do indeed turn on when AC button is on and fan speed is in any position besides off. Found a thread where someone replaced their window ecu because their rear windows went out and it fixed their fan issue too. Got one coming in from a part out so I’ll install that, revert the bypass, and check back in.
Best4x4 (09-11-2020)
Did what the dude said in the mentioned thread about the window ECU. Bought a used one, installed it, and reverted the bypass. Every window works now but I still don't have any fan power. I'm going to try to take the climate control unit out this weekend and see if the window bypass maybe fried something in one of the switches. I'll report back.
