No Heat At All
Old Dec 15, 2019 | 02:43 PM
chewy4000's Avatar
7th Gear
Default No Heat At All
I have changed the thermostat again then Raised front , removed Rad and Resv caps off. Topped off coolant. Ran for a while and the only heat comes when you rev a little but only when parked. The heater core was flushed and no clogging. Strange is one hose out of the 2 from the heater core is warm not both. Also the top Rad to Thermostat hose never gets full or hot.
I can't figure how to get heater working on this 97 SE7.
Thnx in Advance
Old Dec 16, 2019 | 07:16 AM
WaltNYC's Avatar
Hope this doesn't come off a insulting, but is the t-stat installed properly? The side with the spring should be oriented toward the rear of the truck.
Old Dec 16, 2019 | 07:37 AM
chewy4000's Avatar
7th Gear
Not insulting at all. Things happen as they say.
Yes I have it in properly for sure.
Thnx anyway
Broken08
Feb 25, 2019 10:01 PM
chris143007
Aug 12, 2017 09:44 PM
khandrh
Oct 25, 2012 08:16 PM
Rover Rebel
Jan 1, 2011 02:55 PM
Rover Rebel
Nov 23, 2010 04:33 PM
