no spark
Old Sep 1, 2012 | 02:25 PM
Captian Adrianus's Avatar
Default no spark
I have looked through all the "no spark" threads and haven't found my problem.
1995 Disco, 3.9. 187,000 miles. New head gaskets and milled heads.
I started having a problem where every once in a while it would just crank and crank but no start. no sputtering like it wants to start....just cranking. and then after trying to crank for about 5 minutes it would start. then I wouldn't see this problem for a few days. I finally did some tests when It wouldn't start. it is getting good fuel at the rail but, no spark. then after I keep trying, it miraculously gets spark and starts up and runs fine. The problem got more and more frequent. at this point, it will not start at all.
Any ideas?
Old Sep 1, 2012 | 03:17 PM
side note....the coil was tested and is good. But there is no spark out of the coil to the distributor.
Old Sep 1, 2012 | 04:23 PM
Danny Lee 97 Disco's Avatar
Have you tried new wires? Sounds like the coil wire may be bad
Old Sep 1, 2012 | 07:54 PM
Ignition amp modual is bad.
Old Sep 2, 2012 | 04:24 AM
do you know where is it located on a 1995?
Old Sep 2, 2012 | 10:10 AM
Near the distributor.
Old Sep 8, 2012 | 05:47 PM
Repair update:
Thank you Spike. I replaced the ignition module and she started right up.
Old Sep 8, 2012 | 08:45 PM
Thank you for reporting back.
mikedemet
Jan 29, 2021 02:02 PM
ITMagician
Jun 12, 2006 08:37 PM
mikedemet
Mar 7, 2006 12:07 AM
2002DiscoII
Jan 13, 2006 12:29 PM
kfordric
May 30, 2005 11:29 PM
