No vacuum
Old May 24, 2014 | 02:18 PM
wrongway1's Avatar
Default No vacuum
Alright people, I was working on my Disco today & while letting it come up to temp, I got playing around. I pulled the vacuum line on the driver's side where it tees into the cruise control & I have nothing. Put a gauge on & it didn't even move. I followed the soft vacuum lines on the driver's side & although not great, they are intact. Guess the first question is... There should be vacuum at idle, right? If there's supposed to be vacuum at idle, then I have an issue. I never heard a vacuum leak, and do have hesitation when leaving a stop sign, bet never tied that to vacuum. I can't seem to find a vacuum diagram within the rave, or within the search, so does anyone have one in pdf form you can send me?
Old May 24, 2014 | 02:46 PM
OverRover's Avatar
If you are talking about the Tee at the firewall where one hose goes to the CC Actuator(Cruise Control Actuator (Genuine Part # ETC7150 ) - Land Rover switches/control unit/actuators from Atlantic British )
and the other goes to the CC Vacuum Pump( Cruise Control Vacuum Pump (PRC6260 Same Fit As Part # PRC6260 ) - Land Rover switches/control unit/actuators from Atlantic British) ... then NO Vacuum happens until the CC is turned on.
Old May 24, 2014 | 03:09 PM
wrongway1's Avatar
That's the one I'm talking about. Whew!! Had visions of unhappy things heading my way. Thanks for the quick response.
puchungozback
Apr 20, 2007 10:30 AM
anonimaus
Sep 5, 2006 08:37 PM
hzuni
Jan 24, 2006 11:34 PM
hzuni
Jan 10, 2006 12:31 PM
baobab
Feb 11, 2005 02:45 AM
