Noise help please...
Need help id'ing a noise when I'm driving. I can't isolate exactly where it's coming from but it's a high pitch chirping sound from the underside somewhere. I can make it do it when driving in a straight line and slightly turn the wheel to the left, when I straighten back up it quits. It doesn't do it when turned to the right. It stops after a while and it will do it once in a blue moon when first moving in a straight line. I know that's vague but hoping someone may have an idea what's fixing to give out before it gives out.
on
1 Post
I've recently heard that sound, too. I was kinda hoping whatever it was would fly away
. Alot of new sounds after a very rainy humid summer, prolly similar to weather in FL. My sound seems to be coming from up front, on driver side, especially when truck is first driven forward. As ihscouts posted, maybe it's from rust/rubbing on brakes, from humidity/rain overnight
If I find out what's causing my sound, I'll post here.
![Roll Eyes](https://landroverforums.com/forum/images/smilies/Yrp3aj7.png)
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
It's due to the pistons not relaxing enough to draw pads off rotor. Crud buildup on cups and their seals, worn seals, rusted cups and so on and so forth. Couple of cans or Brake Kleen spray on all the calipers and a visual check of the rotors, you'll see drag marks, darkening.
Bearing wear will allow the rotor to shift ever so much to contact the pads. Remember the calipers are attached to the axle and hub casting. They're stationary and the rotors are attached with a nut that's backed off with a bearing and spindle. The rotors will move off axis just enough to hear a chirp of the pad.
The other thing that causes chirping is your U-joints not having any grease. They don't start to vibrate until the bearings are overheated and then begin failing. Chirp like crazy to a trained ear.
