Not just another overheating thread. Sorta.
What was the gauge you installed? Did you do that just because the temp gauge on the dash is useless? Have you noticed a difference between the gauge temp and the temp reported by the ecu/coolant temperature sensor?
And my radiator is one of the new nissens ones. So I don't think it will benefit from being rodded. Haha
And the reason I did that is because I wanted reliable and simple temperatures in the car while I was driving because when I first got it would get real hot. One time before the rebuild the temp climbed to the top on the dash gauge then all Hell broke loose. The oil light came on and it started knocking and I thought for sure it blew up but I must have stuck a lifter. That was when I found a bunch of trash in between the AC condenser and the radiator. I continued to drive it though after switching from the SAE 30 I had in there and going to Rotella. I still run 15-40 after my rebuild too. I did everything you did, everything, but now after my rebuild I see that every thing runs a lot cooler. I don't think I ever mentioned that I run a 160 degree thermostat. Because of how cool its running now I will have to go back to a 190 or 180 before the ski season starts or my heater won't get hot enough to defog my windows.
aceinc
Aug 20, 2013 01:49 PM
