Not so good vibrations
Old Oct 18, 2012 | 12:42 PM
DiscoBlanco's Avatar
Default Not so good vibrations
I've been feeling a slight higher frequency vibration in the 96 Disco lately. It's subtle, but it's there... I sometimes feel it through the steering wheel, but I can feel it very good by resting my hand on the CDL ****.
I'm figuring the front prop shaft, I have not idea if it has ever been rebuilt. Could be an output shaft?
I don't have any serious gear lash or clunking. There has always been a clunk from forward to reverse (but never from reverse to forward). The clunk hasn't changed. Also a small "clunk" that I can feel with my hand resting on the CDL **** when I let on and off the throttle.
Time for a prop shaft rebuild? Or might I have something else going on?
Old Oct 18, 2012 | 03:37 PM
JPSpen's Avatar
You might try greasing the propshaft first..
But a dry U-doesn't last long.. And vibration is the first sign of failure..
Block the wheels.. Put the CDL and in neutral and crawl under and shake things around..
If you have someone you trust.. You can block the wheels and shift the transmission in and out of gear and watch the driveline move around as well.. But that requires someone smart enough to not run you over...I'm fairly certain a LR in low range could roll right over a body at idle...
Hit the grease zerks and grease that puppy up and see if it gets better..
If you have a bad U-joint it's usually pretty obvious. Look for failed seals..
John
Old Oct 18, 2012 | 03:43 PM
yelah's Avatar
If you're putting new Ujoints in, its a good idea to get the shaft balanced while its out. Find a good driveshaft shop, they'll hook ya up
Old Oct 19, 2012 | 09:02 AM
I should say that the rear rubber quibo doesnt look to be at its best on visual inspection, but if that was the culprit, I would imagine I would feel the vibration in the seat?
Old Oct 19, 2012 | 09:33 AM
JPSpen's Avatar
If you can grab the shaft and move that thing around, Then it needs to be replaced..
JOhn
Old Oct 19, 2012 | 11:01 AM
fishEH's Avatar
Bill, if you have the rotoflex still you may want to look at replacing it with a ujointed shaft and four bolt flange. I just bought one for Mihaly off Dweb since his took a dump on the Fall trip. There's another one for sale there too I think. See Crown14's thread.
Old Oct 19, 2012 | 12:15 PM
Thanks Brett! I sent him a PM.
Old Oct 20, 2012 | 08:23 PM
OK, I gave all the zerks a shot of grease... One thing I did notice is that when I hit the zerks on the universal joints, the grease started spitting out right away. I wiggled the shaft as much as I could and it was solid. It rotated a few degrees, but that is gear lash from the transfer case.
The one is the back is looking pretty bad from a close up inspection...
It looks like my diff's are leaking from the output shafts a bit and flinging oil all around. I suppose I should replace the seals at the same time as doing the drive shaft... Is there in inner seal? Will I have to pull the diff? Should I change the bearing while I'm in there?
moj
Nov 22, 2013 01:29 AM
stevenramsey
Apr 16, 2007 12:36 PM
blackdisco2001
Mar 10, 2007 02:14 PM
dewhorse
Mar 27, 2006 11:14 AM
Bene
Apr 27, 2005 12:56 AM
