Not starting
Old Jan 10, 2016 | 06:16 PM
aemnky606's Avatar
Default Not starting
Ok guys,
I have done a few searches on this topic and I have seem to boil it down to the crank shaft sensor but I just want to run it by y'all before I toss parts at her.
First off it has not been on the road in a year as I do some much needed work. I started off replacing front main seal, oil pump, timing chain and gears, water pump, all hoses, fan clutch, new fuel pump, 2 inch lift, and a bunch more.
I have had it running for several months and will drive it down the street every week or two to keep from just sitting. It started just fine yesterday morning, but today when I went to start it and it would just crank and act like it would catch and then just keep turning over. I have fuel at the rail and good battery. I believe I have spark by the way it will catch for a second. So I think the next thing to do is change the crank sensor, am I on the right track here?
Old Jan 10, 2016 | 06:29 PM
ihscouts's Avatar
I can hear, stop yelling.
Two things to know fo show if it's doing what's advertised - Fuel on spark plugs - spark on spark plugs. If your getting spark that's not the crank sensor, if your not getting fuel it's usually the pump. Have ya checked any fuses?
Old Jan 11, 2016 | 09:27 PM
aemnky606's Avatar
I checked all fuses under the hood and the one behind the panel in the truck. I tried again to start it tonight and nothing still.
Old Jan 14, 2016 | 06:08 PM
ihscouts's Avatar
So..... what's new?
Old Jan 14, 2016 | 07:08 PM
Detoured Discovey's Avatar
Probably raining...
I know......I'm no help....
Old Jan 14, 2016 | 07:11 PM
aemnky606's Avatar
So far I have found out that my coil packs are bad. coil number 1 has been arcing to ground and has destroyed the pack. coil 3 and 7 have very bad corrosion in them. so bottom line is they are all getting replaced. I hope that is the fix.
Old Jan 15, 2016 | 04:56 PM
ihscouts's Avatar
Uh, I'd say replacement should get you back to running. Never have seen a terminal THAT bad.........
Old Jan 15, 2016 | 08:57 PM
aemnky606's Avatar
I have not either. Blew my mind when I started pulling wires.
Old Jan 16, 2016 | 07:06 AM
aemnky606's Avatar
And yes it is still raining.
Old Jan 16, 2016 | 01:16 PM
aemnky606's Avatar
ok guys update on my "not Starting". Well after new coil packs, new set of Champion RN11YC4 Copper Plus plugs and wires I turn the key and instantly I have a running truck.
