O2 sensor ses code 1194
I bought a '98 disco w/83k miles for my daughter. Replaced only the front 2 O2 sensors as the back 2 looked newer and drove 100miles (many starts/stops) ,no codes. Drove in the rain, it immediately threw 2 codes,both 1194.
Cleaned both back sensor connectors and drove 75 miles (starts/stops), no codes. Drove it again in the rain, same thing, after the first puddle, 2codes both 1194.
No other issues, truck runs great
Okay what gives here?
My thanks in advance for your help
on
I agree, double check the integreity of the insulation/wiring/ and any in-line splices that may be there.
Since it appears to be moisture related, I would strongly suspect an insulation breakdown some where. Look for abrasion from sharp edges, rubbing or other such issues.
Good luck and keep us posted.
Thanks for the quick reply. I haven't pulled the plugs but the wires are brand new. It is absolutely tied to the water as after 6 hours in the driveway without driving - no codes. Start stop repeatedly in this monsoon and no codes.
I am thinking that I have some nicked wires some place low near the sensors.
I need to get the car through emissions, then after I will take a hose and find the problem.
