Odd running
Old Nov 22, 2018 | 12:13 AM
Sonic's Avatar
3rd Gear
Default Odd running
hi discoland
I am having troubles with my disco 1994 3.9 v8 it flat while driving idles up and down at stand still and will cut out will restart straight away but you have to give a little gas to keep running feels like it's missing this all happens when warm. Truck has brand new dizzy and cap and coil. Have check dizzy and it is firing on number 1. Took plug 1 out rotored motor round till compression came up rotor arm on 1 fired motor up checked with timing light 6deg btc with advance pipe off. Any more ideas please
Old Nov 22, 2018 | 08:29 AM
ihscouts's Avatar
Three things about Lucus distributors that most miss, bearings, advance weights/springs and vacuum diaphragm. How many miles? You might need to rebuild the distributor or get a Davis Unified or GM HEI to replace it with. Idle is also effected by the MAF condition and the IAC and it's circuit needing attention/cleaning. The other thing that could be a problem is the fuel pump and it's inline filter. Those ideas should keep you pretty busy for awhile.......
Old Nov 22, 2018 | 12:36 PM
Sonic's Avatar
3rd Gear
hi thanks for reply the dizzy and cap brand new I will clean and check other things
MudCrawler
Sep 8, 2017 10:03 PM
akitaman
May 25, 2015 08:54 PM
howardw
Aug 21, 2009 06:57 AM
Rover5150
Feb 21, 2008 10:21 AM
commanda
May 18, 2007 11:53 AM
