OEM Brush/Light Guards
Old 01-07-2018, 01:52 PM
jimvw57's Avatar
Originally Posted by ROB99DISCOSD
Cause it’s NLA, no longer available. I just added it for reference.
Sadly, I have that guard on my truck but it seems to be rusting from the inside out. I'd like to replace it but can't seem to locate it.
Old 05-03-2018, 06:19 PM
mirrajumper's Avatar
Wow- were you able to locate one of these? It’s exactly what I have been looking for!!!!!
QUOTE=Paulodelson;632172]Was sent this so fingers crossed that the old duff selling the guard has the right one. And again oem D1 accessories are way tougher to find then lwt parts!
thank you all![/QUOTE]
Old 05-04-2018, 09:25 AM
jimvw57's Avatar
Still looking....
Old 05-04-2018, 10:24 AM
vanbadri's Avatar
Same, mine is rusting from the inside out as well. I have no earthly idea why they chose to cap off the tubes on the bottom. My PO plasti-dipped the whole thing, which seems to have at least masked the problem. I had no idea these things were so hard to get a hold of... At some point I should probably strip it, grind off the rust, bondo and repaint.
Old 05-06-2018, 04:18 PM
jimvw57's Avatar
The matal these were made from was thin, and the rust takes it's toll. I wish someone would make a copy of the original and sell them.
Old 05-13-2018, 01:41 PM
phmancus's Avatar
6th Gear
That's exactly what my buddy and I are doing now. Mine has the infamous rot, so we're making one out of pretty thick tubing, along with a lower profile front bumper. Trying to get it to be burly and OE looking. I'll make a thread with progress eventually.
jimvw57 (05-14-2018)
Old 05-19-2018, 03:42 PM
partsguru's Avatar
I did just pull an STC8457 off my 98 that I have no use for... Not quite as protective for the lights, but would certainly help a radiator!
I have one available ...
Old 05-19-2018, 04:18 PM
Can you post up a picture or the actual item and it’s condition? Thanks
QUOTE=partsguru;648113]I did just pull an STC8457 off my 98 that I have no use for... Not quite as protective for the lights, but would certainly help a radiator!
I have one available ...[/QUOTE]
Old 05-19-2018, 05:40 PM
Saturnine's Avatar
I guess this thread has helped me figure out what I have.. This bar came on my D2, I just thought someone had cut off the headlight wings / bars and just kept the center section. Buuuut.. Looks like it was a factory bit? I have since taken off the lights and plating..
Old 05-19-2018, 06:12 PM
OverRover's Avatar
The A-Frame brush bar for a D2 '99 - '02 is part number: STC50024 and I think they are now NLA.
The stainless steel version was #: STC50025
Quick Reply: OEM Brush/Light Guards
