Offroading In 4X4 Low not diff locked
Old Nov 30, 2012 | 04:17 PM
Lord Wert's Avatar
Lightbulb Offroading In 4X4 Low not diff locked
Is ok to lightly offroad in the standard operation of 4 low unlocked?
Or should you always use diff lock when off road?
Brian
Old Nov 30, 2012 | 04:31 PM
wreckdiver1321's Avatar
It's totally fine to leave the diff unlocked for some light wheeling. It's actually probably better that way. Leaving the diff unlocked is probably nicer to the tcase. If it were me, I'd ONLY engage the diff lock if I was starting to or just about to have a difficult time in low range unlocked.
Old Nov 30, 2012 | 06:30 PM
nahtanoj's Avatar
perfectly fine. most D2's don't even have a diff lock. just high and low on mine.
Old Nov 30, 2012 | 06:36 PM
hilltoppersx's Avatar
not fully true. half of the d2's have the ability to lock the transfer case. but only 04's have the ability to lock the TC with cable linkage it came with from the dealer.
Old Nov 30, 2012 | 09:06 PM
If I'm in lo I'm locked.
But yes, you are fine.
Old Nov 30, 2012 | 10:08 PM
Jake1996D1's Avatar
Brian
Why wouldnt you use diff lock off road?? It's one of the best parts about having an LT230!
What Ed says is true. Your t-case has diff lock you just dont have lever to engage it..
Old Nov 30, 2012 | 10:36 PM
Fivespddisco's Avatar
If you are off road you should always lock your CDL. The Rover Center Diffs are very strong but only when they are locked. When you have wheelspin from your adventures off-road and your CDL is not locked you run the risk of blowing up the spider gears in the differential.
The only reason I can think of unlocking the CDL off-road is to make a tight turn
Old Nov 30, 2012 | 10:38 PM
SSL9000J's Avatar
If you have to wonder if you need your CDL locked or in low, you don't.
Old Dec 1, 2012 | 12:14 AM
nahtanoj's Avatar
my '03 doesn't have a diff lock. i am installing an '04's.
either way, half, over half, most, even if it's there it can't be engaged unless you add linkage to it. if you can't activate it, it's basically not there.
Old Dec 1, 2012 | 06:58 AM
Even without the linkage people can slide under the trucks and turn the nipple manually to engage the diff lock when off road. they just need to be careful not to burn themselves on the flaming hot exhaust and cat.
Francopacks
Apr 30, 2013 12:08 PM
binvanna
Jan 25, 2013 09:50 AM
bullcrew
Jan 11, 2012 12:10 PM
SoCal Detail
Apr 18, 2010 09:02 AM
Bene
May 1, 2005 04:21 AM
