Oil cooler lines subject to failure like Defenders?
Old Oct 31, 2010 | 06:38 PM
PFS's Avatar
PFS
Default Oil cooler lines subject to failure like Defenders?
Hey guys,
Just bought a '99 D1, and noticed the oil cooler lines are routed within about 2" of the exhaust manifold. I changed the lines in our '94 Defender because they had a bad habit of failing, spraying oil onto the exhaust manifold and starting a fire. Just wondering if the D1s have a similar propensity, and if so, what is the best fix.
Thanks,
Pete
Old Oct 31, 2010 | 08:02 PM
No, the DI does not suffer from broken oil cooler or power steering lines that result in a fire.
Old Oct 31, 2010 | 08:03 PM
I would say the best fix is to be proactive and change them before they fail.
Old Nov 1, 2010 | 05:37 PM
Danny Lee 97 Disco's Avatar
One of my transmission cooler lines developed a pinhole leak and was spraying all over the driver's side front wheel well.
Spike are you saying just put new ones on as proactive or should / could they be rerouted somewhat to minimize the problem?
Old Nov 1, 2010 | 05:58 PM
Disco Den's Avatar
By complete coincidence, I came across these today:
http://lucky8llc.com/Products.asp?ProductID=3906
Old Nov 1, 2010 | 06:45 PM
PFS's Avatar
PFS
I've heard of guys putting heat-shielding sleeves on the rubber part of the lines to protect them. Don't know what they used or where they got them though...maybe like a Kevlar-type deal that goes on spark plug wires.
These are the lines I put on my Defender a couple years ago. I know they were pricey, but I don't think I paid THAT much for 'em...yikes! Not sure if they'll work on the D1 yet or not.
http://eastcoastrover.com/110oillines.html
Pete
Old Nov 1, 2010 | 07:09 PM
I wonder if you could go to www.summitracing.com and buy the braided lines and fittings yourself and save a few bucks.
Old Nov 1, 2010 | 07:10 PM
I dont know Danny, maybe just wrap them with a high temp heat tape like they do boat exhaust.
Old Nov 1, 2010 | 09:09 PM
Disco Den's Avatar
Might even be able to get it done at a local custom hose shop. Can't imagine it would run more than $50-$75 per hose.
Old Nov 2, 2010 | 07:05 PM
There is a commercial hydraulic hose shop here in Pittsburgh that had an ad on here saying they will custom manufacture replacement hose while you wait, R.L.Miller Inc, Pittsburgh :
http://www.rlmillerinc.com/
