oil leak from plug
Old Jun 12, 2016 | 05:18 PM
dsmeddy's Avatar
Default oil leak from plug
On a roll last few days...
Next up is how to stop a leak coming out of a plug just above the oil filter? This plughas some sort of retainer ring inside it. Once i get the oil pressure up by revving the engine, out comes some oil. Drip drip drip.....
Old Jun 12, 2016 | 09:59 PM
XCELLER8's Avatar
if it's where I think it is, that may be a pressure relief valve....if you remove the retaining ring........and the planets are alligned correctly, and you have recently made a sacrifice to the Rover Gods.....the spring pressure will push the valve out and you can install a new o-ring on it and put it back together. search and find the correct oring first
Old Jun 13, 2016 | 10:27 AM
dsmeddy's Avatar
Is this the oil pressure relief valve??? And how do I know what part o-ring to get?
The ring with the clip
Old Jun 13, 2016 | 10:28 AM
dsmeddy's Avatar
Old Jun 13, 2016 | 10:09 PM
XCELLER8's Avatar
yup....that's the oil pressure relief valve....the o-ring needs to be exactly what it's meant to be you'll be doing it again....I would bite the bullet and contact a dealer....or a rover repair shop, I've never seen a real part number for it.....but there has to be one..lol...since this engine is basically an old Buick, maybe you could go that route
Old Jun 15, 2016 | 09:10 PM
dsmeddy's Avatar
I went to my local Land Rover dealer in Alpharetta Ga. and lo and behold, they couldn't even tell me the part # nor a proper pic of it. I went and got a O-Ring kit (Viton I believe) and will tackle this soon.
Old Jun 15, 2016 | 11:21 PM
number9's Avatar
Please report back with PN and vendor if good to go. Hope all goes well with the o-ring replacement.
Old Jun 17, 2016 | 02:55 PM
archaeology_student's Avatar
I recently did this... O-Ring size is 19mm x 1.5mm. I found a local supplier here that carried Viton (trademark) o-rings and the parts guy gave me two for free.
You can use any o-ring you want as long as it is 19mm x 1.5mm
The real challenge is reinstalling the relief valve with just two hands... you need one more hand to align everything properly and install the circa-clip back in lol.
Old Jun 19, 2016 | 12:04 PM
dsmeddy's Avatar
Archaeology_Student.... Where in the heck did you find that O-Ring?.... I am getting stumped. I got a Viton kit from Harbor Freights thinking for sure it would have the right size but to no avail.... It did not. Now I have the OPRV out and no O-ring a dingy
Old Jun 19, 2016 | 02:23 PM
dsmeddy,
I phoned a few places locally that sell hydraulic hose fittings and asked if they sold viton branded o-rings, or if they could point me to someone locally. Sometimes it's easier to pick up the phone and make new acquaintances than trying to find stuff online. I eventually found a local supplier called FluidSeal... look for something similar in your area, and give them a call... I jokingly told them it was for a land rover and they warmed up to me
Just give them the size I mentioned when you find your local hydraulic hose fitting supplier 19mm x 1.5mm
