Oil pan gasket replacement
Engine detergents only cause further wear. Loosening up gummed oil will not be completly removed, however it will loosen up and cause trouble you do not want. Drain oil/add oil, wipe off where you can with a clean rag.
You don't need to mess with the engine mounts by the way, just jack up the frame to give you some space between the axle and you can wiggle it out.
Also, before you put the gasket back on clean the **** out of the oil pan with carb cleaner till its sparkling new, make sure the pick up line is clean also.
A tip on putting the pan back on, take some zip ties and put them through the corner and maybe the middle holes of the pan and gasket so that the gasket stays in place when you are positioning and putting the initial bolts back in. It is a bitch to get it to stay in place. Get the back screws in place first, the ones furthest towards the rear of the car because that's where you have the least room. Make sure to use a good layer of rtv, don't be sparse. don't want any leaks again.
Oh and def. do a system flush before you change your oil and clean out the sump.
I'm not entirely sure what the advantage is of switching to diesel oil. Honestly I got the recommendation from Spike. He said he uses Rotella 15w-40 and suggested I do the same. Every other suggestion he's offered turned out to be right on so why not? He mentioned something a out a higher level of detergent in diesel oil that helps clean the engine or something to that effect.
