Oil Pressure Light at Idle
Old Jun 15, 2024 | 07:16 AM
disco96sd's Avatar
Default Oil Pressure Light at Idle
My oil pressure light has started to come on at idle - I put in a new oil pump about 1000 miles ago and I have oil and the engine is not making a racket like it is starving for oil and the light goes off with just a bit of increased RPM's
You think it is likely a failing oil pressure sending switch ?
Thanks
Old Jun 15, 2024 | 09:37 AM
Harvlr's Avatar
How many miles are on your engine? What weight of oil do you use?
Old Jun 15, 2024 | 11:28 AM
Best4x4's Avatar
Is the Oil Pressure Switch OEM Silver & White? Or is it an aftermarket Black & Gold unit? The aftermarket units don't seem to report the proper low PSI. I've worked on a lot of LR's with oil lights flickering and a lot of them had aftermarket Oil Pressure Switches and once swapped over to an OEM unit no more flickering at idle.
Old Jun 16, 2024 | 08:24 AM
disco96sd's Avatar
Thanks - I will check my switch and report back - running 15-40 oil - will check the oil pressure at idle with a gauge soon as I can
UPDATE
Oil light now coming on and staying on even under acceleration but not coming on until the engine is at temp - stays off when engine is cold
Old Jun 16, 2024 | 11:47 AM
Harvlr's Avatar
I think I’d start troubleshooting by plumbing in an oil pressure gauge to see what the oil pressure actually is. Or trying another pressure switch.
Old Jun 16, 2024 | 02:40 PM
disco96sd's Avatar
of course will be checking the pressure before I install a new switch - but for $10 doesn't matter if old one is still good - just keep it for a backup
Old Jun 16, 2024 | 04:42 PM
JohnZo's Avatar
If you want to know about the new switch (or old), it can be tested with regulated air pressure. The switch should activate around 8 psi falling pressure, as I recall. Might be difficult to rig up the fittings, or simply press the rubber end of your blow gun onto the switch. Ohmmeter between metal switch body and the wiring terminal will indicate when it switches.
If the wire is faulting to ground will also cause the light to come on.
Old Jun 17, 2024 | 09:02 AM
disco96sd's Avatar
Thanks on the grounding
Old Jun 18, 2024 | 01:48 PM
disco96sd's Avatar
So I crawled underneath and the oil pressure switch doesn't appear to be leaking and is dry but of course that doesn't mean it isn't bad so I will replace when I do the oil pressure test - what I did discover is my transmission oil cooler line is leaking like a sieve where the rubber hose connects to the hardline in front of the oil pan - it appears to be spraying oil out all over the place as it is under pressure - I don't imagine that leak would have anything to do with the oil pressure light coming on ? ?
Old Jun 18, 2024 | 02:49 PM
Harvlr's Avatar
I’m pretty sure it has nothing to do with it.
