OME lift kit front rake
Old May 20, 2019 | 06:29 AM
gc3's Avatar
gc3
Default OME lift kit front rake
Hey guys, still fiddling with figuring out this poor truck the previous owner did bad things to.
anyways, it was advertised as coming with a 2" OME lift kit.
I see both axles have spacer blocks under the coils.
the rear end looks tall, but the front end is seemingly still at stock height, making it look really raked with the butt up.
I don't know how to tell if this still has stock springs or if it has some aftermarket springs on it.
I feel like i've read that the front vs rear springs on these trucks can get mixed up.
is there a chance that the front vs rear springs are mixed up on this truck?
Old May 20, 2019 | 06:30 AM
gc3's Avatar
gc3
front
rear... i have fixed the swaybar end link issue already
Old May 21, 2019 | 05:55 AM
Toran's Avatar
What is the spacer block material made of? Looks like a bushing.
Old May 21, 2019 | 06:30 AM
gc3's Avatar
gc3
not sure what you are seeing as a bushing, spacer blocks appear to be box tube with anti crush sleeves welded in
Old May 21, 2019 | 06:40 AM
Toran's Avatar
My bad, must be my early morning brain freeze.
Old May 21, 2019 | 06:46 AM
OverRover's Avatar
Those are another version of the poor mans lift kit, just a piece of Rectangular Tube Steel.
Cut it drill some mounting holes, paint and done.
You can get that stuff cheap and in any size at any metal supply shop or places like > https://www.onlinemetals.com/
Old May 21, 2019 | 06:51 AM
Toran's Avatar
Auh very interesting and useful material.
OverRover for President!
Thanks!
Old May 21, 2019 | 07:08 AM
OverRover's Avatar
And if you want to get real fancy you could make these spring spacers out of Aluminum Round Bar for about $20.00
And like the Rectangular Tube Steel, Onlinemetals.com will cut that stuff in any thickness you want cheap.
You can fart around on their website to get a full quote for any material and cut costs.
Old May 21, 2019 | 07:16 AM
Toran's Avatar
Very nice. I have their site bookmarked.
As always thanks for sharing the knowledge.
Old May 21, 2019 | 07:24 AM
OverRover's Avatar
Just in case you ever plan on making theses simple spring spacers and you need some motivation.....
Look at what these turds (and there are other designs) cost retail
> https://www.roversnorth.com/parts/rn...nsion_set_of_4
> Range Rover Classic Discovery Defender Spring Spacer
