Omg i sunk my rig.
Old Apr 26, 2011 | 12:41 PM
  #21
rover11's Avatar
Hows the trans, transfer case and diffs? I cannot wait to see the pictures and video.
Old Apr 26, 2011 | 12:47 PM
  #22
antichrist's Avatar
Change the oil, pull the fuel pump fuse and crank it with the plugs out. If you did get any water in the combustion chambers that will blow it out without hydro-locking the engine.
Just letting it sit with the plugs out won't do it.
Old Apr 26, 2011 | 12:52 PM
  #23
instg8r's Avatar
very true...you need to pump that water out of the cylinders to clear them completely....I've heard also that you would want to fill the engine to the top with cheap new oil and then drain to completely remove any moisture that remains in the engine...but i have not done this nor have I heard that from multiple sources....just putting it out there
Old Apr 26, 2011 | 01:03 PM
  #24
Chris-bob's Avatar
No need for that. Just drain her and fill her back up. Run her to temp and that should boil the moisture out. If the crankcase filled up with water, then you could do that for peace of mind. But if the oil has been changed on a regular basis, the water shouldn't displace the oil where it matters. If you were long past overdue for an oil change, then it couldn't hurt to fill her up to the top.
Old Apr 26, 2011 | 03:51 PM
  #25
Spencerfitch's Avatar
so far differentials and transfercase had a lot of water in them. I dont think any got into my oil or transmission fluid, water was in the chamber [it sat A WHILE]
and its in my power steering for sure!!
Old Apr 26, 2011 | 06:53 PM
  #26
Cosmic88's Avatar
Default 1000 words
pictures, pictures, we want pictures.... and video.
To be real honest I want to see the video of the truck entering the water. I'd like to listen for engine noises and to see at what point things went wrong (besides driving through 4 feet of water to start with). Also, did you shut the engine down or did it die? And how long was it in the water?
Come on now...
Old Apr 26, 2011 | 07:45 PM
  #27
I cant wait to see the pics.
Did you shut it off or did it stall?
Old Apr 26, 2011 | 08:44 PM
  #28
your gonna be let down on the picture and video, its not that glamourous and crappy quality.
Old Apr 26, 2011 | 09:06 PM
  #29
tornado_735's Avatar
What the hell did you do!?!?!? Lol
Old Apr 26, 2011 | 09:08 PM
  #30
ok so I need help, I dont quite understand this whole wet electrical dealio..
So my windows rolled down by themself but I rolled them up after a few trys. However they went back down and now will not return.
Does this mean its permanently damaged or just wet still?
Also the little red light on my dash is constantly glowing.. Security.... But it never did this before.. Im in the process of drying everything out right now..
