One last lift question
Old Jul 25, 2012 | 04:25 PM
deer4011's Avatar
Default One last lift question
So I want to get a 2" lift on my disco 1. The guy from rovers north said that I need to get longer springs to accommodate the lift.y question is if I need to get shocks or not.
Old Jul 25, 2012 | 04:34 PM
fishEH's Avatar
The longer springs IS the lift. You don't NEED to do anything. But running stock shocks on a lift will severely limit your down travel. I would recommend new longer shocks with the springs.
Old Jul 25, 2012 | 05:44 PM
deer4011's Avatar
Could I just get lower shock mounts
Old Jul 25, 2012 | 06:18 PM
If all you are looking for is a 2" lift, do not worry about changing the mounts.
What sort and how hard a wheeling will you be do?
Don't buy your lift from them.
Have you looked for any specific lift kits yet?
And Yes, you will need new shocks
How tall a tire are you going to install?
Old Jul 25, 2012 | 06:44 PM
fishEH's Avatar
You could, but the lowered front and rear mounts will probably cost you the same as some longer Terra Firma shocks.
Old Jul 25, 2012 | 09:25 PM
Scharfire's Avatar
sorry to be blunt but if you are doing any sort of lift do it right. get new shocks. i know its going to be a punch to the wallet but honestly i say just do it right and you will not have to go back later to fix a botch lift job.
Old Jul 25, 2012 | 09:29 PM
fishEH's Avatar
Agreed. Going cheap f*ck hack doesn't pay.
Old Jul 25, 2012 | 10:12 PM
Cassidy Bodle's Avatar
i am new to land rovers but i was also looking at the lowered shock mounts to go with the 2" springs.
i like the idea that stock shocks will still fit "i can replace them at the local parts store" is there a bigger downside i am not seeing?
Old Jul 25, 2012 | 10:30 PM
Scharfire's Avatar
if you use your stock shock with any lift you will severely limit you down travel. your flex will be next to nothing. if you are doing a lift for the looks you shouldn't own a land rover. if you want something that looks good lifted that has no functionality lift a chevy truck with ifs. its pointless to lift ifs trucks. not trying to be rude but if you are lifting a land rover and going to run bigger tires you will lose mpg and stability just for a look. not worth it. lowered shock mounts is like a bandaid. it will fall off and leave you without anything.
again not to be rude or disrespectful but do it right the first time.
Old Jul 25, 2012 | 10:40 PM
deer4011's Avatar
Nothing too advanced on the wheeling question just mud rocks and inclines. And where would be a good place to install them
