one more fuel grade inquery
Old 05-31-2011, 07:23 PM
Originally Posted by hilltoppersx
you are good to go with 91+. I always put 91+ unless im in the middle of nowhere and i know the 91 has been sitting for months if not years, then i will put 87 just because bad gas is worse than low octane gas.
Amen brother!! I made the mistake once several years ago of wiping the cob webs off of the premium fuel pump handle at a no name gas station in a name no name town while on a 'froadin' trip and my truck spit and spuddered and bucked and yawed...but she got us home.
Topped of with Shell premium and she ran great.
Lesson learned, 87 is ok once in a blue moon or in a emergency but not as a steady diet.
Old 05-31-2011, 07:51 PM
thehun's Avatar
Originally Posted by Spike555
MPG all depends on the amount of ethanol in the fuel, the more ethanol the lower the MPG.
All of my state has 10% ethanol in the fuels no matter what grade
87 runs poorly in my disco as well but she runs tip top with 89
Old 05-31-2011, 08:34 PM
Whatever works for you man.
I ran 89 for a few tanks and noticed a difference.
Right now I am using Costco premium, my truck idles kinda rough when hot but runs fine down the road, cant tell a difference in mpg.
I want to switch back to Shell but damn the $.06 per gal savings is hard to pass up.
Old 05-31-2011, 10:04 PM
thehun's Avatar
I wish Amoco or BP would be in my area..but no
Old 06-01-2011, 01:20 AM
ShadowMerchantBC's Avatar
Banned
Back to my original question... premium or Super premium (which I've been using)???
Old 06-01-2011, 01:45 AM
jbriggs's Avatar
The words Premium and Super premium don't mean anything. You have to go by the octane, 87,88,89,90 ect ect.
Old 06-01-2011, 01:59 AM
Banned
91 as well. So which is it? Different owners are using different grades. Which one is most highly recommended and best for the engine long term? Would that be 91 since its the highest?
Old 06-01-2011, 02:05 AM
jbriggs's Avatar
Whatever you can afford. 91 is better but 89 and 90 are good.
Old 06-01-2011, 10:43 AM
Chris-bob's Avatar
Have you looked in your owners manual at the manufactures recommended fuel grade? Also, octane rating has no affect on fuel economy. If you think you got different fuel economy with a different octane, and think it was because if the octane rating, you are blowing smoke.
Old 06-01-2011, 02:03 PM
Dodger's Avatar
I can shed some light on this subject, and that is just don't! Only use 91+ octane, all these engines lack an egr system. The lower the octane, the higher the cylinder temp, causing the oil to burn in the heads. Eventually all the sludge in the heads will block off the return passages and starve the engine for oil and it will do something crazy like throw a rod (that is what my truck did before I got it). Not to mention when you really think about it the cost difference is very little compared to a new engine. My wife's Mercedes is the same way and it has two knock sensors, yet it is only rated for premium fuel.
Quick Reply: one more fuel grade inquery
