which one of these champion plugs should i order?!?!?
Old Nov 3, 2010 | 05:47 PM
booper169's Avatar
Default which one of these champion plugs should i order?!?!?
http://www.championsparkplugs.com/re...p?AAIA=1316063
Old Nov 3, 2010 | 06:23 PM
Single platinum or the copper.
Personally though I think I would go with these.
http://www.autozone.com/autozone/par...er=505356_0_0_
Old Nov 3, 2010 | 07:35 PM
booper169's Avatar
i have 8mm magnecor wires too i should say
Old Nov 3, 2010 | 07:57 PM
booper169's Avatar
You think the NGK will perform better than the OEM champion brand even if its the double platinum? i have magnecor wires too..
Old Nov 3, 2010 | 08:10 PM
bantham1's Avatar
NGK is probably the best plug out there. Champion is okay but not as high quality as NGK.
Old Nov 3, 2010 | 08:30 PM
x100.
Old Nov 3, 2010 | 09:09 PM
antichrist's Avatar
RN11YC4
Personally I use whatever I can get cheap locally. Usually it's Autolite, but sometimes Champion or NGK. Can't tell a bit of difference.
Make/size of wires is irrelevant.
Old Nov 3, 2010 | 09:11 PM
booper169's Avatar
Is there any of the ngk models to stay away from?
Old Nov 3, 2010 | 09:15 PM
bantham1's Avatar
I have used the plain copper NGK TR6 on a ford lightning engine and they held up for 70k miles. The TR6 is a colder plug and is specifically for high performance supercharged application.s The gap was a little big and do not recommend running them that long but they will hold up. I put the platinum NGK in my 98 D1 and it runs great with the new wires. Platinum is not good for high performance/supercharged applications but is fine for stock. Make sure you get the stock heat range if your engine is not highly modified.
Old Nov 3, 2010 | 09:42 PM
booper169's Avatar
Seems like Ngk is pretty popular. Anyone else using them in their d1? I thought most people were using champion
