Overheating but not at idle
Old Jun 3, 2019 | 11:33 PM
keyesjosh's Avatar
4wd High
Default Overheating but not at idle
98' Disco overheats only while driving and returns to normal temps while stopped or at idle. New stat.. Pumps good and no leaks. 218k miles. Is this a sign of plugged radiator or air in system? If plugged radiator will a pro flush help?
Old Jun 4, 2019 | 07:08 AM
WaltNYC's Avatar
A new fan clutch is cheaper than a re-cored or new radiator.
Amazon Amazon
In the end, I did both.
At 218k I would very much expect both to need attention.
Old Jun 4, 2019 | 07:14 AM
keyesjosh's Avatar
4wd High
How do I tell if clutch fan is bad?
Old Jun 4, 2019 | 07:47 AM
whiskeynipple0088's Avatar
when the fan clutch is engaged it should sound like a jet engine under the hood when you accelerate.
also if you can spin the 'cold engine' fan and it continues to spin = bad
plus if its got over 100k - its likely bad
they have viscous fluid in them that wheres out or leaks out over time
Old Jun 4, 2019 | 07:54 AM
keyesjosh's Avatar
4wd High
Roger that. I'll do a spin test. Anyone wire a/c fan on a switch to keep it on as needed? Looking to have some extra air flow and want a/c fan on as needed but not sure how to wire.
Old Jun 4, 2019 | 08:11 AM
WaltNYC's Avatar
My experience was that typical fan clutch "spin test" was not conclusive. For $30 just replace it.
Some have wired A/C fans to turn on manually. Should be some threads about that here.
While shopping, a $12 IR temp gun is a handy tool to help diagnose temp issues as it helps pinpoint hot spots and cooler spots.
Old Jun 4, 2019 | 10:23 AM
keyesjosh's Avatar
4wd High
Fan spun freely while cold. Started engine and was able to stop fan with a piece of cardboard with minimal resistance. Bad fan clutch it is.
Old Jun 4, 2019 | 10:52 AM
whoa - yeah Id say so
FYI - I had originally replaced mine with a URO brand and it was always engaged. Beck/Arnley brand is twice as much but it works properly.
Old Jun 10, 2019 | 02:48 PM
yossi's Avatar
3rd Gear
https://www.amazon.com/dp/B000C3F31G...v_ov_lig_dp_it
Just a quick question, has anyone tried the SKP SK46071 fan clutch? It's on
amazon amazon
Old Jun 10, 2019 | 05:28 PM
OverRover's Avatar
The SKP is just another cheap POS ( $29.79 @RockAuto ), Made in China fan clutch.
