Overheating, coolant leaking, some smoke
Merry Christmas everyone,
today my lovely discovery decided to **** coolant everywhere and overheat. It is a 98 disco 4.0 auto trans with 173000 Miles. So before today I did noticed I had a slow coolant leak wasn’t sure where it was coming from and have been working nonstop so I haven’t had time to check. I just keep and eye on fluid levels and temp. Today I started to notice loud waterfall noises coming from the heater core followed by slow warmup temps and then the temp going up to 220. I pulled over to let it cool down to try not to blow any head gaskets. I popped the bonnet and noticed coolant was leaking out of the top of the expansion tank. The radiator was just record 5months ago, I figure the initial leak is a hose. I did notice some thin bluish white smoke coming out of the exhaust upon startup the second time. My question is should I be looking for head gasket issues? Can air in my system cause overheating issues and possible smoky exhaust? Thank you for any help!
If you system is pressurizing, the first thing I'd check is for exhaust gasses in the coolant. A test $25 test kit will give you some indication. They are not always 100% accurate, but they are a good first and low cost first step.
I hope I'm wrong but what you describe sure does sound like a blown head gasket.
Ehamp (12-26-2019)
flanker6
01-15-2013 01:15 AM
