P1138 DTC - finding the true cause
My P1317 code is gone, only to be replaced by P1138 ('96 SE7 5-speed). I took a look at the freeze-frame data and it looks like I may have a vacuum leak. I haven't had time to look at the live data for the O2 sensors yet. Is this most likely caused by a vacuum leak, or should I be looking at the O2 sensors instead? Freeze-frame data is pasted below:
DTC for which Freeze Frame was Stored P1138
Fuel System 1 Status Open Loop - due to detected system fault
Fuel System 2 Status Closed Loop
Calculated LOAD Value 54.51 %
Engine Coolant Temp 174.20 °F
Short Term Fuel Trim - Bank 1 24.22 %
Long Term Fuel Trim - Bank 1 6.25 %
Short Term Fuel Trim - Bank 2 -1.56 %
Long Term Fuel Trim - Bank 2 6.25 %
Engine RPM 1,966.00 rpm
Vehicle Speed Sensor 37.28 mph
15degreeGTI
05-16-2013 02:30 PM
philander
08-19-2011 04:20 PM
surf9ska
02-14-2006 03:52 PM
