p1179 and p3999 codes??? what is wrong with my land rover?
hooked up my code reader i just bought and found the codes p1179 and p3999... what do i need to do to get the check engine light off!
Fix the codes. Start by downloading the RAVE(in my signature) and do a search for the codes. Then use the troubleshooting guide to find and fix your problems.
(sure, we could just tell you the answers, but anyone owning an older Land Rover needs to learn to find the info themselves and fix it themselves the right way the first time, or get rid of the Rover. It's not a vehicle for those that won't do their own research.)
p1179.....air mass flow rate correction at maximum negative value...(could even be a poor seal at the gas cap) or an air leak.... somewhere......
the othe code supposedly doesnt exist ......
www.codereader.com
what sort of maintenance have you done, any repairs lately ?, any other symptoms ?
www.codereader.com
chris-bob if i knew what it was then i wouldnt put it on here.... i can not find the code p3999... i did my research and did not find it...and thank u xcellar8... i will try to clean the maf sensor and clear the codes...
LR1LE50th
Oct 4, 2014 06:28 PM
zer0Point
Apr 22, 2012 06:37 PM
