P1448 error code?
Hey guys yesterday my CEL came on and the code was P1448. My truck runs fine and sounds ok. What does the code mean? Gas cap, fuel lines, purge valve & canister which I can't find anywere. Is this something I can drive with or does it need to be fixed immediately?
Generally, they are located on the pax side against the inner wheel well. Download the RAVE so you have access to the info you need, such as component location and troubleshooting tips.
Ok I downloaded the RAVE. So much information. I could read it over and over again. Now I checked my lines they look fine no cracks and everything hooked up nice and tight. Is there a certain way to clean the purge valve, my CEL is still on? The RAVE tells me how to take it off, but I couldn't find how to service it.
