P1448 error code?
Old Jan 10, 2011 | 11:22 AM
pimnmike's Avatar
Default P1448 error code?
Hey guys yesterday my CEL came on and the code was P1448. My truck runs fine and sounds ok. What does the code mean? Gas cap, fuel lines, purge valve & canister which I can't find anywere. Is this something I can drive with or does it need to be fixed immediately?
Old Jan 10, 2011 | 11:54 AM
Chris-bob's Avatar
The P1448 fault indicates a leak in the evaps system. Check all of the vacum lines that go to and from the purge canister and valve. look for cracks and the like.
Old Jan 10, 2011 | 12:29 PM
pimnmike's Avatar
Where is the canister and valve?
Old Jan 10, 2011 | 12:54 PM
Chris-bob's Avatar
Generally, they are located on the pax side against the inner wheel well. Download the RAVE so you have access to the info you need, such as component location and troubleshooting tips.
Old Jan 11, 2011 | 12:49 PM
Danny Lee 97 Disco's Avatar
It looks like a black coffee can with two hoses attached to the top sitting on the passenger wheel well inside under the hood.
X2 on downloading and using the RAVE.
Old Jan 12, 2011 | 08:00 AM
The code, more specifically is the evap purge valve flow 2 fault.
Old Jan 27, 2011 | 01:00 AM
pimnmike's Avatar
Ok I downloaded the RAVE. So much information. I could read it over and over again. Now I checked my lines they look fine no cracks and everything hooked up nice and tight. Is there a certain way to clean the purge valve, my CEL is still on? The RAVE tells me how to take it off, but I couldn't find how to service it.
jason9500
May 12, 2008 01:11 PM
jason9500
May 12, 2008 08:21 AM
cdparker
Sep 9, 2006 12:16 PM
Bugman
Apr 27, 2005 01:20 AM
Bugman
Apr 26, 2005 12:32 AM
