Paired alarm and engine ecu
Old Mar 27, 2020 | 07:37 PM
aemnky606's Avatar
Default Paired alarm and engine ecu
Looking for a set of paired alarm and engine ecu’s For a 96 D1. Let me know what you got. Thanks
Old Mar 27, 2020 | 07:47 PM
ihscouts's Avatar
Paul Grant or Will Tillery.
Old Mar 27, 2020 | 07:54 PM
aemnky606's Avatar
Paul does not have any. Already talked to him. For the life of me I could not remember Will Tillery. I will shoot him an email. Thanks for the reminder.
Old Mar 28, 2020 | 05:24 PM
Best4x4's Avatar
As long as the Alarm ECU is active you can usually slap in a new ECU without having to touch the green Alarm ECU under the passenger side dash. I've done it many many many times. It's only when you get an ECU out of a P38 that is not setup for the D1 Alarm ECU that you usually run into a no start condition = T4 programming time.
Old Mar 28, 2020 | 07:44 PM
aemnky606's Avatar
I have swapped ECU several times and no issues also. But out of the blue the truck won’t start. Hooked up my lynx and had a code that the ECU has not received signal from alarm. Key fobs don’t work and have solid red light on dash. I can’t even connect to the alarm ECU with the lynx.
Old Mar 29, 2020 | 09:39 AM
Best4x4's Avatar
I had that once and I replaced the green alarm box with a spare I grabbed out of a junk yard vehicle and was good to go. When I was using the lynx on the original unit it apparently lost communication during programming and made the original totally INOP. I honestly DO NOT touch the lynx alarm programming anymore. I'll program a remote, but I will not try to config the alarm box options anymore. Not sure if it was a glitch, or what, but those green boxes don't grow on tree's anymore.
Old Mar 29, 2020 | 03:36 PM
aemnky606's Avatar
Yes I have killed a green box with the lynx before. I never do anything security except remotes. I think there is a bug in the programming for it. I think this time the alarm box just failed on it own.
Old Mar 30, 2020 | 07:00 PM
aemnky606's Avatar
Truck is up and running. Thank you Will Tillery for the Paired units.
Old Mar 31, 2020 | 05:11 AM
ihscouts's Avatar
Yea!!!!!! I knew one of em would take care of ya. HOT commodity, the herd is getting thinner by the minute.
Old Mar 31, 2020 | 04:21 PM
aemnky606's Avatar
Yes they are. Hope this is the first and last time the alarm craps out.
gprtech
Dec 23, 2020 12:16 AM
aemnky606
Mar 29, 2020 03:39 PM
EricTyrrell
Feb 18, 2013 11:31 AM
jordamf
Oct 7, 2010 08:54 PM
fanshadow
Jan 26, 2006 12:10 AM
