Parasitic battery drain....shocker i know
Old Jan 25, 2025 | 06:41 AM
Trashpanda's Avatar
Default Parasitic battery drain....shocker i know
98 d1
New coil pack
New good testing battery and alternator
When I got the car I was told the battery would drain over a few days and it started draining over night. I pulled the green door locking box and it went back to draining every 3 or 4 days. My fuel gauge doesn't work and I only have .5v at the harness when it should be 5v so I've been going and cleaning the grounds only to find there are no engine to body grounds.
Any other ideas to look at while I go through this process with the grounds?
Old Jan 25, 2025 | 02:10 PM
JohnZo's Avatar
Maybe use an ammeter function to measure the amps draw. Then pull fuses (amps go to near zero) to see which fuse (or fuses) have the highest draw. Focus on that circuit to eliminate any load that should not be there (a relay, light, or OBD device for example). Or just leave that fuse out until you want to drive again.
The problem could be some PO modification. My '96 can go well over a month without draining the battery. Dirty ground connections do not cause the battery to drain, unless the battery is not getting fully charged.
Old Jan 25, 2025 | 02:23 PM
Trashpanda's Avatar
the radio wiring is also an absolute nightmare, im going to have to try them interference thing you mentioned on the other thread
Old Feb 8, 2025 | 03:11 PM
Trashpanda's Avatar
I've narrowed it to the windowlift/cdl/rear blower circuit
Old Feb 8, 2025 | 07:42 PM
Harvlr's Avatar
That’s good troubleshooting. Good job.
Old Feb 8, 2025 | 07:45 PM
Trashpanda's Avatar
thanks, after removing literally every fuse from the interior panel and not eliminating the drain, it has to be somewhere between the engine bay fuse block and the interior fuse block
Old Feb 15, 2025 | 11:12 PM
JohnZo's Avatar
So maybe the insulation got rubbed off passing through the fire wall, creating a partial short circuit?
Old Feb 15, 2025 | 11:32 PM
Trashpanda's Avatar
perhaps, i don't have a garage and it's been rainy so i havent had time to look into it
Kevhdkent
Jun 6, 2023 08:16 AM
Richard Gallant
May 21, 2019 10:23 AM
bcbp
Sep 3, 2015 07:47 AM
Texarican
Jan 7, 2012 05:12 PM
2000 Disco 2 SD7
Jan 25, 2009 02:59 PM
