Parking brake light turns on while making turns
Old Jun 26, 2013 | 10:23 AM
Lord Wert's Avatar
Default Parking brake light turns on while making turns
my Parking brake light turns on while making turns on curvy roads. all of my pads are worn down and will be replace this weekend. Is this a "your brakes are shot" indicator?
My parking brake doesnt do much in terms of holding the truck where it is when you set it (also seems like worn pads again)
Also, a recommendations of brand and source for pads and rotors would be appreciated.
thanks.
brian
96 disco 171K auto trans
Old Jun 26, 2013 | 12:12 PM
DiscoJag's Avatar
Hi Brian. I have a '96 SD too. I like Akebono brake pads. No nasty dust and they work very well. I think the pads might be the cause of the brake light coming on. The parking brake on mine is't real good either. The parking brake on these actually squeezes the drive shaft, I believe the rear one. So there will be some slop in there. The rotors, I'm not sure. It's been a while since I replaced mine, but I get most of my parts from a well-known Jaguar-Land Rover site which I don't think is a sponsor of this forum. ;^)
Old Jun 26, 2013 | 05:16 PM
jastutte's Avatar
check your brake fluid. might be low. the reservoir has a baffle in the middle, so make sure there is fluid in both the front and back.
Old Jun 26, 2013 | 06:54 PM
Rover_Hokie's Avatar
X2 brake fluid is moving side to side and causing a low fluid reading. If your fluid is not golden in color, probably time to change it out as well.
Old Jul 3, 2013 | 12:25 PM
Lord Wert's Avatar
Exclamation
My fluid was a little low. So that solves the light coming on while turning. MY fluid is light brownish so I will need to change it. A problem I noticed. When I had the master cyl cap off to add fluid, when screwing it back on it does not fully tighten, It tightens but when you get it close to being sealed it pops back off and needs to be screwed on again. Is my cap defective. The seal looks good and there' no leaks from the are around the cap. Im far from a braking expert but cant afford mechanic labor rates. I would appreciate some tips on flushing fluid and maintenance of the master cyl
thank
Brian
Old Jul 4, 2013 | 07:52 AM
TOM R's Avatar
my cap also does this, definitely flush out all the discolored fluid and if you were that low to set off a light all the fluid is setting in the calipers you need to check pads, now when you do pads all that extra fluid you just added will be on the ground clean it up good it eats paint
when flushing start farthest from the master cyl do pass rear, driver rear, pass front, driver front
ign off all the time break open bleeder with wrench then close with full master and cap on have someone pump breaks a few times and hold, open bleeder pedal goes to floor hold it there till bleeder is closed then pump and bleed, repeat till clear fluid, at each wheel
may want to spray lube the bleeders first to soak em and if you can suck the old fluid from the master and put clean in there is goes faster
also after a few bleeds on each caliper check the master keep it full with cap on
tibyABv6
Dec 18, 2012 10:09 PM
nomar07
Mar 29, 2012 02:29 PM
sjewell
Oct 12, 2011 11:20 PM
tango123
Mar 5, 2009 05:26 PM
