Parking and dash lights not on - is it the switch
I have a 1998 D1 that I bought today and i'm trying to trace down an issue. I have no parking lights or dash lights...the headlights work fine. When i turn the switch very slowly, the lights will turn on, but as soon as i turn i a little further they go back off. Two questions:
1: I think this is the switch, do you think that is the case?
2: I've removed the shroud and the two little screws that hold the switch in place, but it is still in there tight. how do i get the switch out?
Thanks for any help.
Thank you very much for the responses. I've removed the two screws, but that switch assembly is still in there tight. I saw another post mentioning using a jewelrs screw driver to pop it out, but i didn't understand where exactly they were pressing.
Does anyone know the trick to popping out the assembly once i have the screws out?
on
I have my old one downstairs, I will have to take another look at it. Seems like I had to sort of pry it out. I will dig it out of my large box of removed items and see if there are any clues left. I will get back to you.
On mine, If I forced it around with pliers, the lights worked that time but you had to force it each time, so I figured it was shot. Will got one to me in a couple of days.
Some people on here had written up threads where they dis-assembled theirs and did some kind of internal hocus pocus repair and reassembled them, but i gave up on that and got a used one from Will. It works fine.
It really isnt that hard. I just took it apart, 4 screws. The contacts were absolutely nasty from corrosion caused by moisture... so I took my dremel, attatched the wire wheel and cleaned the contacts. I put some dielectric grease on the contacts so they wouldnt corrode again and put it all back together and it works like new. It took me 15 minutes. The hard part was finding where the two springs went cuz it all flew out at me when I took it apart. The two springs go in the main piece with all the contacts. Trust me, its very simple to fix.
on
Well I kept my old one if anyone wants it, let me know. Just cover shipping and a beer or two and it is yours.
tibyABv6
12-18-2012 10:09 PM
1998, 98, dash lights, disco, disco 1, land, lights, parking, parking lights, pdf, removal, rover, signal switch, switch, working
