Parts List Check For Front Cover Gasket Replacement
I am ordering the parts for replacing the front timing cover, and I wanted to make sure I am not missing anything. Here is what I have so far.
* Front cover gasket (Genuine)
* Water pump gasket (Genuine)
* Front crankshaft oil seal (Genuine)
* Tube of Hylomar Blue
* Front Cover Bolt Kit - GEMS
* KD Tools 3136-76 Ford Fan Clutch Wrench 36mm Long
* Schley (SP 61600) Universal Fan Clutch Wrench
Anything else I might need while I have it torn down?
Thanks!
Thanks!
Get the O ring for the cam sensor. You would be better off ditching the Hylomar and getting a tube of HondaBond or ThreeBond. Any motorcycle shop carries ThreeBond, just tell them you want the stuff to seal the case halves, they'll know what you want. It's about $8 a tube and is impervious to fuel, oil, and coolant. You should probably drop the oil pan and clean it and the screen. I use Ultra Gray permatex after everything is clean and oil free. You need only a thin bead, you can use some long bolts to guide the pan back up so you don't smear it.
You don't really need the fan clutch tools, a 10" adjustable and 1/2" breaker bar will work fine. Use the breaker bar to add tension to the belt and smack the adjustable toward the passenger side to loosen the clutch.
The gasket can be a biotch to get off. I use a brand new wood chisel and keep it flat to the gasket surface to peel the gasket off. You do have to be careful with it but it is the fastest way to get the old gasket off.
So, is HondaBond or ThreeBond that much better than Hylomar Blue?
ThreeBond and HondaBond(as well as KawasakiBond and Yamabond) are used in place of gaskets on dirt bikes mostly. I also use it on the valley pan end seals, around the coolant ports on the head and intake, and for both sections of the plenum. It's easier to get and cheaper than the loctite stuff they say to use. You don't even need the gasket, the ThreeBond will seal and never leak if you cleaned everything good. I would have used it for the oil pan but is isn't meant to take up large clearances, best for precisely machined surfaces.
Yes you are already there and that would be a great time to do it if it needed to be done.
But I wouldn't touch it.
I'll certainly check those items, but I don't plan on replacing unless it's necessary. I just want to fix the leak in the cover and the one at the crankshaft oil seal.
