Passenger door lock switch doesn't work.
Old Oct 27, 2012 | 01:37 PM
LRchick's Avatar
Unhappy Passenger door lock switch doesn't work.
Ok so I am having a problem with my passenger door.
I can't open it from either the inside or the outside without holding the lock switch about 1/8th of an inch above door frame.
It will open from the outside only if I leave the key in on the unlock position. Otherwise it won't work.
The driver side does work and all the others unlock when I put the key in but its just the passengers side that will not open from the outside unless someone is holding it above door frame as I stated before.
I even worked on my parts vehicle to see if I could fix it but no result.
Any idea what this could be? Anyone had this problem? If so how can I fix it?
Thanks.
Old Oct 27, 2012 | 06:09 PM
antichrist's Avatar
It really sounds like an adjustment issue and I expect you'll need to take the door panel off to dig in to it.
If you don't have them yet, I'd get the appropriate shop manual. You can get them hard copy, or electronic various placed around the net.
Here're the links to one source. RAVE download
Old Oct 29, 2012 | 03:18 PM
jfall's Avatar
What does holding it above the door frame mean?
What are you holding?
The key FOB / transmitter??
If you are talking about the FOB - sounds like time to replace the battery.
Holding the FOB above the door frame allows the UHF radio signal an easier path into the receiver thru the glass.
The door metal (aluminum) will block the signal.
Old Oct 29, 2012 | 05:32 PM
tooltech's Avatar
She means the plastic locking switch lever doohicky, the one that sticks out about an inch and a half above the door frame in the unlocked position.
LRchick, if it's not the locking actuator motor, then it's the locking linkage. To check to see if it's the motor itself, first close all doors except the problem door. Then using your finger to press in the courtesy switch (light/door ajar), and putting your ear close to the panel, with other hand press the LOCK button on your keyless remote. Press UNLOCK. Do this as many times as you need to listen for any noise behind the panel. If there is noise, then motor is working. Pull off panel (you can find videos on youtube) and check linkage. There may be noise, and yet still need a new motor though, due to it not having enough power to operate the linkage.
Old Oct 30, 2012 | 01:15 AM
LRchick's Avatar
Thanks I appreciate the help. :-) guess after exams this week its time to fix my door :-)
Old Nov 8, 2012 | 10:04 PM
benakbs's Avatar
Had the same problem on my 96...replaced the actuator and it didnt help. It ended up being a broken spring in the door latch itself. There's a guy on ebay that makes replacement springs who is in the UK. I ordered a set for the whole truck for $30 shipped and the locks work great now. I'll try to find the thread with the link...
The username of the guy on ebay is phillipstuart33
http://cgi.ebay.com/Land-Rover-Disco...item20bbd02cec
Old Nov 9, 2012 | 09:03 AM
LRchick's Avatar
Thanks I did remove the actuator and it wasn't the problem either. And if your problem was what mine is as it sounds like it is. Was it difficult to replace?
Old Nov 9, 2012 | 04:59 PM
benakbs's Avatar
It requires a lot of patience. The door latch has to be removed from the door, after that, replacing the spring is pretty easy. The most difficult part for me was maneuvering the latch out of the door. The springs come with some instructions on what needs to be done, but I recommend printing out the diagram out of the Rave manual of the linkage so that you can reassemble it much easier.
jamanta
Sep 4, 2015 02:33 PM
cosmiccharlie
Audio/Visual Electronics
Mar 29, 2013 09:34 AM
00&04 Disco
Oct 20, 2010 04:14 PM
Rustic
Oct 13, 2009 11:02 AM
NC1999HSE
Apr 14, 2007 12:39 PM
