Sponsored by: CARiD
remote doesn't work
Old Apr 10, 2006 | 06:08 PM
NC1999HSE's Avatar
4th Gear
Default remote doesn't work
I disconnected the battery replaced the left Blend motor and now the remote won't work and doesn't set the alarm. I have tried the usual resync things but it still doesn't work. Any help would be great.[:@]
Old Apr 10, 2006 | 11:03 PM
Bait's Avatar
Default RE: remote doesn't work
What kinda Rover? Year, model, etc...
Old Apr 11, 2006 | 11:15 AM
NC1999HSE's Avatar
4th Gear
1999 4.6 HSE
Old Apr 11, 2006 | 07:43 PM
05LandRover's Avatar
what did the dealership say?
is it still in warranty?
Old Apr 11, 2006 | 11:23 PM
Bait's Avatar
Bad Drivers door latch. Only one remote?
Old Apr 13, 2006 | 06:49 PM
NC1999HSE's Avatar
4th Gear
I will have to try and find my other remote and try that one.
I find it would be weird if it was the door latch as the remote stopped working right after I disconnected the battery.
The car isn't under warranty and the nearest dealership is 1 hour away. I would like to try to fix it myself but don't know what else to try.
Old Apr 13, 2006 | 11:48 PM
Bait's Avatar
ORIGINAL: NC1999HSE
The remotes lose sync when the battery is disconnected. The only way to re-sync them is with the drivers door lock procedure. If you find the other remote and it will also not work, you have a bad latch.
Hope that makes sense, let us know.
Old Apr 25, 2006 | 02:43 PM
NC1999HSE's Avatar
4th Gear
I finally fixed it!!!!!!!!!!!!!!
I used the EKA method of disarming the alarm and then was able to resinc my remotes. Yeah!!
Thanks for the input.
I found the method on www.rangerover.net
Old Apr 14, 2007 | 12:39 PM
ptasker's Avatar
Hi NC
Can you tell me the last bit of the eka method, on my card it says see reverse, but it is a copy and therefore blank.
Regards
Paul
00&04 Disco
Oct 20, 2010 04:14 PM
Rustic
Oct 13, 2009 11:02 AM
dillhole
Aug 7, 2008 04:10 PM
chig
Jul 21, 2008 02:33 PM
lionel
Oct 15, 2007 10:53 AM
