Passenger seat trim removal?
Some what new to wrenching on the disco but I’ve been searching the threads and looking through the rave manual and I can’t seem to find how to get the black studs out to remove the side cover. Any help? Need to get my carpets up.
my passenger side carpet pad is soaked and still searching for the cause of that as well. AC drains cleared, no issues with headliner. Footwell and side well is dry up underneath. Puzzled
thanks for the replies
As Army Rover said, a Trim Removal Tool will help pop those black caps off easily; cheap and can be found at any Autozone or O'Reilly's locally.
https://www.autozone.com/test-scan-a...ool/103001_0_0
https://www.oreillyauto.com/detail/b...iscovery?pos=4
As far as the wet carpet...it could be the heater core leaking as it looks like you have a D2:
https://landroverforums.com/forum/di...re-leak-47651/
It is a D1, 1995, but will it be the same process to check on the D1 as D2? Plus on 65xxx on the clock.
No coolant smell, fairly odorless(less a slight musty smell as water sitting covered up smells). I poured water over the windscreen with no evidence of leaks. Same thing around the sunroof.
Got the mats pulled. Here’s what the damage looks like. Not sure if that says anything about where water could be coming from. It looks like one of the seams was leaking but it just doesn’t seem possible that it could completely saturate the mats. Worth treating the rust? It’s somewhat minor.
