Pitman arm!!!!
Old Oct 31, 2011 | 03:17 AM
wheelgarage's Avatar
Default Pitman arm!!!!
I give up.
I cannot find a big enough puller locally to rent or to buy. I did find some online, but I don't want to wait any longer. My plan is to go to a local shop to have it pulled off. Then, I can start to rebuild the box!!!
Old Oct 31, 2011 | 03:39 AM
JumPeR04's Avatar
i rent mine from autozone and it fit just fine.....
Old Oct 31, 2011 | 12:21 PM
Which one did you get? I couldn't find it online...
Old Oct 31, 2011 | 01:13 PM
fishEH's Avatar
I used a pulled and had to beat the snot out of it while applying the puller. It finally POPPED off but it was crazy tough.
Old Oct 31, 2011 | 01:16 PM
jezzz......I should have beat on it for a bit.....
Autozone gave me some specs of the one they have. I am going to chk it out. If not, there is a garage around the corner.
Old Oct 31, 2011 | 01:31 PM
Danny Lee 97 Disco's Avatar
Yeah, let some fat greasy old redneck smack it for you. They enjoy that.
Old Oct 31, 2011 | 03:48 PM
The one at Autozone was the same exact one that O'Rielly's had, that will not work. I drove around to different shops, no luck. They all didnt have one big enough to pull off. I just called a British Specialist about 30 min away. Waiting too see if they can do it......
Old Oct 31, 2011 | 04:12 PM
AntiChrist, got any advice?
Old Oct 31, 2011 | 05:48 PM
antichrist's Avatar
Yeah, search.
https://landroverforums.com/forum/ge...rop-arm-40683/
For the OP, if you don't want to buy one you should be able to get it pulled at a Ford truck dealer. Probably any medium duty truck dealer for that matter.
Old Oct 31, 2011 | 08:39 PM
That OTC one from that online retailer is cheap....about half-price than the local retailers.
consulting with wife.....but its Halloween time!!!
