Please Help-Siezed front Pass Caliper. Tried Replacing MC, Caliper, and Hoses
Old Jul 7, 2011 | 07:37 AM
priceg's Avatar
The reason I asked about the master cylinder, is, I have had more than one occasion where the air gap from the booster to the master cylinder was too tight causing the master cylinder to engage. I have stopped using after market cylinders and only use factory parts for this repair. If you can open the bleeder valves on the calipers,and release the pressure, you have diagnosed your master cylinder as being pre loaded. Hope this helps.
Old Jul 7, 2011 | 10:26 AM
Chris-bob's Avatar
I would start looking into the abs manifold. Might be a valve that is normally open, acting as check valve because of crap buildup. If you don't want your abs, now might be a good time to bybass it completely and remove the manifold/pump.
Old Jul 7, 2011 | 11:45 AM
zracin's Avatar
Ok, I replaced the ABS unit, still have the problem. priceg you must be right, Ill be picking up a LR MC today. Im going to feel so rediculous if the first part I replaced was bad....such a waste of time and money...Oh well, I learned how to replace an entire braking system.
Old Jul 19, 2011 | 06:23 PM
zracin's Avatar
Got an OEM MC, fixed the problem straight away. meaning I have a good ABS unit, and proportioning valve for sale should anyone need them
Old Jul 20, 2011 | 02:09 PM
Danny Lee 97 Disco's Avatar
Great Lesson Learned.
Old Jul 20, 2011 | 03:13 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Sounds like a damaged master cylinder.
Old Jul 31, 2011 | 03:15 PM
zracin's Avatar
replaced with an OEM MC. but with 20psi vacuum bleeder on it, the Rear Dirverside caliper would not bleed out any fluid. but it would if you pressed the pedal with your foot hard. was a clog in the hard line connector under front wheel well. I cleared it out, brakes work fine now.
Old Jul 31, 2011 | 03:43 PM
Thank you so much for reporting back!!!
If I hadn't eaten all the cookies I would give you one.
jaw7091987
Jan 30, 2012 08:01 PM
fuctifano
Dec 22, 2010 08:55 AM
95RRlwb
Jun 11, 2009 09:28 AM
cold_surfer
Mar 21, 2007 01:38 AM
