Poor MPG problem
Old Mar 10, 2017 | 08:38 AM
AbnMike's Avatar
Default Poor MPG problem
I'm still trying to track down what I think is a very poor MPG problem, even for a Discovery (last tank I averaged 8.3 mpg. Granted that is in in-town driving, back and forth to work, 2 miles each way (no preaching, I'd bike if I could but I live off a road that's 2 miles long, barely 2 lanes wide, no shoulders, immediate drop off into ditches or worse).
To save time: I don't floor it. I coast to stop lights. On highway I run about 65-70 mph, I don't pass unnecessarily, etc.
25k miles ago it got new heads and gaskets, camshaft, hydraulic lifters, timing chain and gears, valve cover gaskets, ignition wires, vacuum hoses and Magnaflow stainless steel Y pipe and catalytic converters
Highway MPG couple months ago (pre new wires and plugs)
800 mile round trip 10.2 mpg average at 2200 rpm.
Scan tool showed Long Term Fuel Trim (LTFT) 16.9%
On December 28 I threw a P1316 #E8 Misfire Excessive Emissions Fault
Cleared it and haven't seen it since.
New Plugs. New Wires. New Upstream O2 sensors.
In January I went to I13-14mpg range (Highway) with the new front 02 sensors (over hilly/mountain terrain up and down through WV and western MD). The LongTerm Fuel Trim has been a solid 3.1 over 300 miles, down from a high of 10.2.
Shortly after it jumped up to 14.7% (no changes in anything on the Disco)
Put in a new fuel pump and fuel filter - Previous Fuel pressure was around 28. New filter and pump has it about 30 psi.
Fuel trim dropped after new filter to 4.2%
Over past couple of weeks drove it and it jumped back up to 9% then has been back down to 4.2 and is now at 6.3%
At this point I'm at a loss.
Took it to a shop for an intake "smoke" test to see if there are any vacuum leaks leading to it running lean and dumping fuel (per Discoweb advice).
Test shows no vacuum leaks. They used a scan tool and wrote up the following
Smoke Test results negative. No Leaks found. 2: Following vehicle data shows Charged Air Temperature Sensor Reading -36 Degrees. MAF Reading at 1.74 GPS should be Between 3 and 4 GPS AIT Temp should be just about Ambient Air Temp.
Ok, cool. Talk to the guy and he says my MAF is slightly out of spec but not bad but my Charged Air Temp Sensor is really out of spec and reading -36 Degrees would make my truck run very rich! I thank them and go home to look for this $7 sensor.
BIG PROBLEM.
When I plug in my Scan Tool my IAT (Intake Ambient Air?) reads slightly warmer than outside air but not much (Yesterday after idling awhile it was at 124 degrees (64 outside temp) but then I drove it around and it dropped to 95 or so (outside temp 60) - so 30 degrees different but it is inside a plastic box in a pretty hot aluminum engine bay).
This morning it was 35 degrees and the IAT was showing around 50 (and it does move up and down as though it's working).
So the mech said the IAT of -36 would definitely cause the engine to run rich (dense air - computer throws more fuel at it). Makes sense.
What I don't get is why my IAT reading on my OBDII is showing a more or less correct IAT reading. It doesn't make sense that they'd make up something (it's a $10 part at best).
Is their tool reading some other Charged Air Intake temperature other than what I think it is (the sensor in the airbox)?
Is their tool reading a reading off the MAF instead?
Did they just completely screw up?
All of this said and done, I still have very crappy mpg, even for a lifted Disco. No vacuum leaks. New plugs and wires. New fuel pump and filter. Proper fuel pressure. New 02 sensors.
Still crappy mpg.
The only thing I could possibly think is that maybe I have a leak at my exhaust manifold to pipe and it's sucking air in there and fooling the 02 sensor to think it's lean so it's dumping more fuel...but those gaskets are new, too.
Old Mar 10, 2017 | 09:38 AM
AbnMike's Avatar
Note I'm basing all this on being told that high LTFT numbers are a result of an engine running lean (or telling the computer it is) and dumping extra fuel into the motor as a result.
Old Mar 10, 2017 | 10:02 AM
RedRovin''s Avatar
I don't have anything valuable to add, but I'm subscribing to this for my own reference. I'm only averaging 11-12 mpg highway, so hopefully I can learn something to help it out a little
Old Mar 10, 2017 | 10:24 AM
ihscouts's Avatar
One thing is for sure, city driving kills a GEMS motor with carbon build up on the pistons. That alone hurts mileage in a big way. The other item is compression, nobody has mentioned it but if the rings are coked it's all moot.
Old Mar 10, 2017 | 10:49 AM
ihscouts's Avatar
There's only one sensor for air temp. The MAF only measures volume, no provision for temp. The coolant temp for the ECU is most important and then the air temp sensor. Pretty sure you get a check engine light if that one is out of spec. Any dragging calipers or bearings not being greased?
Old Mar 10, 2017 | 11:19 AM
AbnMike's Avatar
The coolant temp stays around 180 or so.
No caliper drag that I'm aware of. New bearings all around. Rolls easily enough for a 6,000 vehicle when on a hill...
I'll take it out for an Italian tune- up and see if I can't clear out some of the coked up crap and use an injector cleaner in it and see what happens...
I guess I need to go back to the shop and ask them why my IAT shows correct intake air temp but theirs shows it at -36. Maybe they're reading something different?
Old Mar 13, 2017 | 07:36 AM
AbnMike's Avatar
So on Friday I put in some Techron super duper cleaner stuff in a full tank and drove it around a bit. Parked it Friday night, didn't drive it Sat or Sunday.
Woke up this morning and started it and got these:
WTF?
Attached Thumbnails Poor MPG problem-misfire-1.png   Poor MPG problem-misfire-2.png
Old Mar 13, 2017 | 02:05 PM
ihscouts's Avatar
Lol, good stuff, right in keeping with it's a Rovah.
Old Mar 13, 2017 | 02:10 PM
AbnMike's Avatar
So does it sound like I need new injectors? I hate to start just throwing parts at a problem but I'm not getting any answers really.
Was told it was a result of a vacuum leak. No vacuum leaks.
Told to replace plugs and wires. Replaced plugs and wires.
Maybe it's a bad fuel pump. Replaced fuel pump and fuel filter.
Bad MAF? Ok the MAF is apparently a bit out of spec but that's the same shop that said my IAT was showing -36 except my OBDII shows it operating properly. I guess I could replace the IAT sensor for the hell of it.
The only thing left is injectors....
Old Mar 13, 2017 | 02:18 PM
ihscouts's Avatar
How is it running right now? Can you snag another MAF to check against cuz that's where I'm leaning? Not injectors, they're being cleaned, that Techron is some kinda wonderful, it'll dissolve just about anything.
