Possible Knock Sensor Error Code?
Old Jul 9, 2020 | 03:27 PM
Toran's Avatar
Default Possible Knock Sensor Error Code?
Hello Good People,
A little over a month ago while removing the starter I bumped and broke the knock sensor. I have since replaced the starter (new) and the knock sensor(used) and soon after I am now getting a P1316 code. Before I bumped the sensor and before replacing the starter I had no error code or CEL. Right now the truck is running rough with only the P1316 code. Would this be related to the knock sensor?
Two years ago I did:
Reconditioned cylinder heads
Head Gaskets
New STI Plug Wires
Champion Spark Plugs
New Fuel Filter
Thanks
Old Jul 9, 2020 | 09:43 PM
DiscoNewbe's Avatar
Originally Posted by Toran
Hello Good People,
Head Gaskets
New STI Plug Wires
New Fuel Filter
Thanks
When I replaced the starter on my 99’ D1 I bumped that same sensor and actually broke the plastic connector. It was one of my first fixes and I wasn’t as quick to replace the sensor as I should have been. Needless to say a month later I put in a new knock sensor and it ran just the same during that time...
Having said that, I would’ve thought having a broken sensor would have thrown some kind of code, but it never did...I would think the engine should run rough if it’s minus one of its knock sensor because you’d think the engine would assume a worst conditions scenario and run differently.
Old Jul 10, 2020 | 12:55 AM
Toran's Avatar
The truck is running rough right now, and that knock sensor is the only thing I replaced while since the starter ordeal. Before it was running strong with no codes. I have always ran with at least 92 octane fuel.
Interesting that you drove without one and it never put out an error code.
Thanks for the response.
Old Jul 10, 2020 | 12:21 PM
Toran's Avatar
Could my faulty ignition switch be responsible for the P1316 code?
A couple of weeks ago I had a starting related issue that I thought was from the starter. It turned out to be the ignition switch. As a temp setup I connected a momentary switch to the starter and the battery and the truck fires right up with the key in the 2nd position.
Thanks
Old Jul 12, 2020 | 03:44 AM
Toran's Avatar
Wow, now I have amazingly created a cross thread and cannot get the knock sensor properly seated.
Can this be bypassed or what?
Picked up a screw from Homedept, will take a dremal or hacksaw and cut a slit into the screw, and than fit the screw into the truck with the hope of re-threading so the knock sensor can be properly seated.
Thanks
Old Jul 26, 2020 | 03:32 PM
Toran's Avatar
Hello Everyone,
I got the knock sensor seated in the truck but it is still running rough as in 30% to 40% power decline.
All the plug wires are all seated properly.
No vacuum leak.
What are your thoughts?
Could a bad ignition coil be responsible for power decline and the engine not starting before I connected the momentary switch to the starter?
Thanks
Rovergirl2001
Jul 28, 2021 09:24 AM
msm15
May 11, 2016 07:57 AM
elpapisf
Jan 27, 2013 09:53 PM
rholtporsche
Mar 9, 2012 09:37 AM
jck09
Mar 22, 2010 10:10 AM
