Potential Fuel pump problem
Old Feb 28, 2011 | 05:13 PM
disco-montana's Avatar
Default Potential Fuel pump problem
Hello, I think I am having potential fuel pump problems. My disco stalled about 3 or 4 times now, on an practically empty and half filled tank. That and when ever I start it, it starts up strong, but loses a tiny amount of power right after wards. My question is this, is my fuel pump going out? or are there other potential issues? I have looked at other posts like this, and have found others with similar problems / issues. Thanks in advance.
Old Feb 28, 2011 | 06:11 PM
roving patrol's Avatar
When was the last time you replaced your fuel filter? Dirty fuel injections could cause that problem too! Check the pressure of you fuel pump. Check you vacuum hoses for cracks too!
Old Mar 12, 2011 | 12:32 AM
Default New fuel filter
I had a new fuel filter installed. It works much better now, less hesitation, smoother shifting / power delivery. Thanks for the tip. It helped out and was cheap also. Thanks
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
