power loss
Old Jul 13, 2014 | 05:53 PM
TOM R's Avatar
Default power loss
been having serious intermittant power loss lately, 300 miles ago I had a p0158? bank 2 o2? cleared it and never came back ug shows volt, tps, mph, temp, o2,s intake temp all normal but I push the gas pedal and nothing though tps reading increases
actualy seriously looses speed on inclines at 50 mph last tank of gas i got 170 miles highway, this tank got 259 which is about normal all on super
4 tanks ago I filled up at a shell before this started I always get wawa gas did I get bad gas or fuel pump going?
does not miss or sputter just no power, if I push almost to the floor it kicks into passing gear and engine screams trying to get back up to speed like i am riding the brakes, brakes are not getting hot and abs pump fuse is out
this happens with and without a/c on and is very annoying but intermittant, seems worse when it is in the 90's ambient but engine temp is 185*
Old Mar 13, 2015 | 06:40 PM
TOM R's Avatar
P0158 has returned, no other codes ??
Old Mar 13, 2015 | 09:25 PM
ihscouts's Avatar
Did you get this from the other ECM as well?
Old Mar 13, 2015 | 10:12 PM
TOM R's Avatar
I think when I originally posted above the other ecm was in can't remember, I think this came from a weird startup issue I have in warm weather once and a while
Once and a while I start the hot engine in warm weather it runs weird like its rich or something like the chokes on then Smith's out but the sensors show normal
Now done it with both ecm, and before I did the injectors and fpr , maybe I need to check crank sensor wiring? For that issue
Not sure on the 0158
Old Mar 13, 2015 | 10:59 PM
ihscouts's Avatar
Are you running with a vented gas cap or non-vented?
Old Mar 14, 2015 | 10:08 AM
TOM R's Avatar
I run the original cap, I have a spare from another ael d1
Old Mar 14, 2015 | 11:51 AM
ihscouts's Avatar
Could be a bad cat, vacuum leak, bad downstream 02, or a wiring problem. With this popping on two separate ECM's is highly unlikely it's either of those.
Old Mar 14, 2015 | 01:12 PM
TOM R's Avatar
Well, no cats, replaced both upstreams , down streams are blocked, I've had upper and lower plenums off and sealed with hylomar so I am thinking wireing?
Old Mar 14, 2015 | 01:40 PM
ihscouts's Avatar
Yep, looks like that's it. I did a little research on P0158. The reason I rule out the ECM's is because there is no way both ECM's would have reference voltage to that particular 02 out of whack. So wire is where it's at.
Old Mar 14, 2015 | 04:20 PM
TOM R's Avatar
Guess I need to check the harness good when I rebuild the engine
