Power Steering Leak
Power Steering Leak
Having power steering issue and need help for 99 SD. Always has leaked a small amount which was never an issue. About 2 week ago, drove it for less than 3 miles and parked it in the driveway when I returned home. The next morning came out to drive it and found most of the fluid on the driveway:
Replaced the PS hoses with all new ones and all was good, have driven the car almost daily since replacing the hoses. Drove it today and it has happened again. Drove about 8 miles and parked it for about an hour and a half. When I got back to the disco, it had the same puddle as before and the fluid reservoir was empty. Topped of the fluid and drove it home. It's been sitting for 3 hours now with only a few drops of fluid underneath, no big leak as before.
Has anyone experienced a similar issue? Doesn't make since to me that it ran fine for nearly 2 weeks without issue after replacing the PS hoses only to have it happen again. And it's not leaking out after refilling and driving again.
Any Advise?
Thanks,
Disco99
Any Advise?
Thanks,
Disco99
In my situation I was leaking fluid bigtime. I would top it off before going to work, and would have to add more before leaving work. I added Lucas Transmission Fix and it slowed down the leak, The next morning I topped it off with a little more Lucas and the rest is history. Now I have few drops to the point I have to add a little Lucas every 3 weeks or so.
Again temp solution to get you out of a jam. Depending on your leak this may buy you some time. No ratio, just pour the slow-n-thick red stuff in and drive the truck.
https://lucasoil.com/products/proble...ansmission-fix
You should probably drain some put before you put it in. Also remove that mesh filter from the reservoir before you add it, if you have one. The Lucas won’t strain through it.
I’m struggling with P/S issues as well. Not leaking on the ground, but the hoses are coated in fluid. I too would like to know how to pin-point diagnose bad hoses, bad pump, or leaky reservoir.
Just fix it
I went through the same thing. Just drop the box and reseal it. Make sure the shafts aren’t slopping around first, then replace the input seals or output seals, or both. It’s just gonna dump at the wrong time and place and cause you to also eat a pump. The trans fluid is getting all over your front suspension bushings and killing them also. If you have time get a spare box and reseal it and just swap them out.
Hatchetjack (04-07-2021)
Update
Just wanted to provide an update. Added Lucas and the leak has slowed, only a few drops here and there periodically. Spent some time looking for the origin of leak and looks like it is from the front of the steering box. Planning to find a used box that I can rebuild and swap out with the leaking one. Then rebuild that one and have as a spare for when needed.
Thanks for all the input!
