Proline fuel pump help...
Old Feb 21, 2011 | 01:32 PM
dansgt's Avatar
Default Proline fuel pump help...
so i've figured my pump is out, fed it power and nothing. trying to order from rovers north and their saying i need a new wiring harness for it, but i didnt see anything about that on here. can someone confirm this before i spend an extra 55 on something i dont need? if it comes to that i'll probably just order from Atlantic British...
Old Feb 21, 2011 | 01:37 PM
Danny Lee 97 Disco's Avatar
I don't know what wire harness they are talking about. I put one of their pre-AEL fuel pump assemblies in my early 97 which is identical to the 96 and iut was plug and play as far as electrical. You may need the fittings for the fuel lines themselves.
Old Feb 21, 2011 | 01:39 PM
dansgt's Avatar
http://www.roversnorth.com/store/p-6...discovery.aspx
this is what they are saying i may need. do you know, did yours come with the gasket?
Old Feb 21, 2011 | 03:02 PM
jafir's Avatar
Maybe they have problems with corrosion. I bought the pump from them, on my 96, and they asked about that harness, but didn't try to push it on me. I told them the connectors looked fine and I was getting power to the pump.
Old Feb 21, 2011 | 03:35 PM
dansgt's Avatar
so its basically just a replacement end with the same connector?
Old Feb 21, 2011 | 03:59 PM
jafir's Avatar
Not sure, I didn't buy it
Old Feb 21, 2011 | 04:15 PM
dansgt's Avatar
lol but obviously it worked without it right?
Old Feb 21, 2011 | 04:20 PM
jafir's Avatar
yes, worked fine. and it was also on a 96. Maybe they catch on fire or something? I've seen alternator plugs for some american cars that the wiring gets a little toasty sometimes.
Old Feb 21, 2011 | 04:32 PM
dansgt's Avatar
yea my wirings fine, so are all the connectors for the fuel lines, no rust like everyone else seams to get since it is a california car, and i'm 100% sure its the fuel pump now so imma order it. as long as i get it before weather gets bad again i'm happy, dont mind driving the mustang around haha.
Old Feb 21, 2011 | 06:25 PM
demonlarry's Avatar
on some the connector is different. mine had the 4 pole connector.
worst case scenario, buy it, if you don't need it return it.
doesn't come with a gasket.
