Pulley scratch replace or repair?
Old Aug 28, 2016 | 12:26 PM
photo2u's Avatar
Default Pulley scratch replace or repair?
Damper pulley
Hello friends,
In the process of reinstalling a new water pump, One of the three bolts holding the pulley to the pump broke. Additionally, I scratched the pulley slightly with the home made removal tool I created for this install.
My questions are as following: Would the balance of the pully compromised due to the scratch? Is it appropriate to replace the bolts with simple hex type bolt rather than the flange type? I have at hand some nice stainless steel hex bolt with size appropriate lock washers.
Please advise,
Gorge
Old Aug 28, 2016 | 10:55 PM
XCELLER8's Avatar
use a good bolt & washer.....(not a grade 2 from the hardware store) and you'll be fine.
you didnt give us a pic of your "scratch" but it's unlikely that the balance would be affected.....you do want to make sure that the belt surface is smooth
Old Aug 29, 2016 | 02:26 PM
photo2u's Avatar
Thanks for the information.
The scratch was not very deep. I sand the area and repaint. I also used grade 10 bolts from autozone.
I now have water leaking from the thermostat area. I truly hope that is not something major. I applied 28 foot pounds of torque to t he thermostat housing. Should give I tightener a bit more?
Please advice,
George
Old Sep 1, 2016 | 07:29 PM
mr4x4's Avatar
Rave says to torque thermostat housing to 28 nm wich is 20 ftlbs
Your torque is sufficient, but have you replaced the thermostat housing/water outlets gasket lately.
usnavylt
LR4
May 1, 2015 03:40 AM
Spencerfitch
Detailing
Apr 8, 2013 10:38 PM
hubie
Jun 22, 2010 05:41 PM
andrewmcoffin
Mar 10, 2008 08:52 AM
al_disco
Detailing
Apr 5, 2007 12:20 PM
