Question about PCV mod
Old Feb 9, 2022 | 08:22 PM
JohnZo's Avatar
Default Question about PCV mod
Best, I wonder have you considered adding an oil catch container?
Old Feb 9, 2022 | 08:28 PM
Best4x4's Avatar
Never thought about it, but there is plenty of space to add one. I've had great luck with adding a PCV to a D2 so I just came up with the D1 mod of the same design/idea.
Old Feb 11, 2022 | 11:48 AM
JohnZo's Avatar
I am wondering if the little bit of oil that gets into the intake is bad, or maybe it is actually beneficial to the engine. There are drain holes bored into the trumpet bases after all.
Old Feb 11, 2022 | 05:11 PM
Best4x4's Avatar
A little bit of oil is normal, the main reason for the PCV vs the baffle is a serviceable item you can easily check/service vs the baffle which crumbles and easily can clog causing unwanted crankcase pressure and then the valve covers are usually the first to go.
Best4x4
Nov 10, 2025 09:29 PM
Brandon318
Oct 18, 2021 12:27 PM
andino
May 18, 2021 12:27 PM
Toran
Aug 26, 2020 08:36 PM
Brandon318
Apr 10, 2019 02:24 AM
