Question about swapping ARB air locker to new D1
Old Apr 10, 2014 | 11:20 PM
roach131313's Avatar
Default Question about swapping ARB air locker to new D1
I recently bought a new D1 to replace my old, tired, dead one. My old D1 was equipped with front and rear air lockers that I'd like to put into the new one. Can this be a straight swap of differential housings? If I don't have to pull the locker out of the old housing and do a full, from scratch, install into the new differential, I'd like to avoid it. I was thinking I could just pull the front pinion cover off and swap it onto the new D1.
Those that part Rovers, have you ever done this?
Thanks,
Old Apr 11, 2014 | 12:04 AM
CUpgt's Avatar
Well first off I'm not sure what your referring to as "pinion cover". It's no problem to swap them over, however you need to pull your axle shafts and disconnect the drive shafts. Then pull out the old third members, install the ones with the lockers and reinstall axles add oil and reconnect drive shafts. You will also have to install the compressor, run new air lines and install switches. A TON of people swap thirds in and out, including myself.
Old Apr 11, 2014 | 12:14 AM
jhmover's Avatar
There's no drama here. I just did the same thing.
bclayt
LR4
Mar 3, 2016 05:16 PM
bclayt
Nov 20, 2015 10:42 AM
GRover96
Jan 28, 2015 11:12 AM
fishEH
Mar 6, 2013 09:43 AM
mcvickoffroad
Mar 5, 2013 08:21 PM
