Quick Sensor Question
Old Oct 5, 2011 | 02:10 PM
thehun's Avatar
Default Quick Sensor Question
What is the sensor that is on the driver's side, has a heatshield and right in front of the y-pipe
Old Oct 5, 2011 | 03:16 PM
See attached: are you talking about something mounted to transfer case (vehicle speed sensor), etc.?
File Type: pdf
Old Oct 5, 2011 | 05:16 PM
thehun's Avatar
Nope..its the sensor where the ypipe and the exhaust mani meet up by the engine..there is a sensor there....im trying to find out which sensor is causing my water crossing issue
Also...another question..what is the sensor on the left bottom side of the water pump?
Old Oct 5, 2011 | 05:20 PM
jafir's Avatar
Probably crank sensor
Probably cam sensor
Old Oct 5, 2011 | 05:36 PM
Chris-bob's Avatar
Crank sensor is under(somewhat) the water pump.
editDamn...I was wrong...Cam sensor is under the water pump.
Old Oct 5, 2011 | 05:45 PM
Paul Grant's Avatar
Cam sensor is below the water pump on the engine cover. The crank sensor is on the drivers side about where the starter is on the passenger side. The cover is a pita to remove when the left exhaust manifold is in place. It's a pair of 6 or 7 mm bolts of differing length that hold the assembly in place.
Old Oct 5, 2011 | 05:46 PM
thehun's Avatar
I think that is whats getting wet (cam sensor) and giving me idle issues after water crossing...because now think of it..when I changed out my thermostat...i got antifreeze all over the water pump...when I cranked the engine..it started to do the same erratic idling as when I cross water...BINGO
Old Oct 5, 2011 | 05:48 PM
Paul Grant's Avatar
Make sure the wiring is in good shape. Clean everything up, including the sensor itself. You don't want to know how much a new one is going for these days. Thanks to Ford destroying so many of the Land Rover legacy parts, the last time I checked, I could buy a DI for less than the cost of a CPS new.
Old Oct 5, 2011 | 06:17 PM
Sensor - Camshaft | Land Rover Engine Parts at RoverParts.com
Old Oct 5, 2011 | 11:16 PM
thehun's Avatar
o wow...expensive
