Radio
Old Nov 11, 2011 | 09:33 AM
jbunner's Avatar
Unhappy Radio
Hey, I disconnected the battery to work on the lights. My grandson kept trying to get the radio to work and kept pushing the buttons without the code and now the radio won't work at all. I had the code in the glove box but he didn't know. Is the radio toast now?
Old Nov 11, 2011 | 09:41 AM
Suspect if you disconnect battery for 10 minutes and try with code you should be OK.
Old Nov 14, 2011 | 07:55 AM
jbunner's Avatar
Hey, I disconnected and reconnected the battery and now I don't have any power to radio. Will check fuses.
Old Nov 14, 2011 | 06:10 PM
atancreti's Avatar
Check the fuses, once you get power to the radio, turn it on and let it sit MAKE SURE ignition is in the number II position. I let mine sit for an hr then came out and entered the code... BAM radio worked...
dogstarsix75
Apr 24, 2020 01:33 PM
lvshust
Aug 21, 2018 02:29 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
