Radio code
Old May 5, 2015 | 12:23 PM
SteveGT's Avatar
Default Radio code
Hello,
Looks like my battery died briefly at some point because now the clock is about two hours behind and now the stock radio wont turn on. I turn it on and the LCD panel says: "Code".
Is this something I have to call the dealer for, or is there another way?
Thanks
Old May 5, 2015 | 12:38 PM
WaltNYC's Avatar
Dealer should be able to help if it is the original radio. You'll need the vehicle VIN. Write the code on the bottom of the long rubber 'tray' on the dash.
Old May 5, 2015 | 03:58 PM
philwarner's Avatar
A dealer's service dept in Little Rock gave me the code for my radio and it worked.
Do check the rubber oddiment tray liner - sometimes the code is already written there - and check the owner's manual if you have one to see if a PO wrote it in the manual. Otherwise, call the nearest LR service department as suggested.
You'll have to enter the code any time the battery is disconnected.
dogstarsix75
Apr 24, 2020 01:33 PM
sayeedA
Nov 15, 2011 11:02 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
